Master Permissions in PowerSteering: Control Access Without Complexity
Get permissions right—and keep them right.
In this on‑demand Powering Ask the Expert session, you’ll learn how PowerSteering permissions really work and how to configure them confidently to support your organization’s governance model.
Permissions are foundational to how teams interact with projects, data, and system functionality. Yet they’re often misunderstood—or overcomplicated. This 25‑minute walkthrough breaks permissions down into practical, manageable concepts so administrators can apply them correctly and avoid downstream issues.
Watch now to learn how to:
  • Understand PowerSteering permission targets (projects, users, system-wide objects, and more)
  • Use Defined Categories vs. Default Permissions effectively
  • Assign permissions through roles, groups, and the Everybody set—without over-permissioning
  • Apply permission best practices for projects, work items, and system-wide access
  • Avoid common configuration mistakes that create maintenance headaches later
You’ll see real examples inside PowerSteering, including how permissions are inherited across work items, how roles and custom sets interact, and when (and when not) to use user-level overrides.
Whether you’re new to PowerSteering administration or looking to tighten governance as usage scales, this session gives you the clarity you need to configure permissions with confidence.
Watch On-Demand
Watch On-Demand
All fields are required
