Microsoft Academic Federated Connector for Search
The BA Insight Microsoft Academic Federated Connector integrates Microsoft Academic—a bibliographic database developed by Microsoft Research that indexes publications and journal articles—with internal enterprise search applications. It provides researchers and knowledge workers with a unified view of up-to-date information from both Microsoft Academic and all relevant internal sources.
With this connector, users can simultaneously search Microsoft Academic and internal content using the familiar BA Insight SmartHub interface, eliminating the need to search Microsoft Academic separately. It retrieves a single combined result set from over 90 content sources accessible via BA Insight connectors, allowing users to apply filters across all data sources to narrow search results. Results link directly back to the original Microsoft Academic record with a single click.
Problems Microsoft Academic Federated Connector for Search Solves
Purple Slanted Bullet Point
Fragmented research workflows due to separate academic and internal searches.
Blue Slanted Bullet Point
Inefficiencies retrieving and consolidating publication and internal data.
Difficulty filtering large, disparate datasets across multiple repositories.
Ensuring up-to-date access to both external scholarly and internal organizational knowledge.
Benefits Microsoft Academic Federated Connector for Search Delivers
Key Features of the Microsoft Academic Federated Connector for Search
Use the left and right arrow keys to move between tabs. Swipe or drag to scroll through more tabs. Press Enter or Space to activate a tab.
Federated Search
Federated Search
Simultaneous querying of Microsoft Academic and internal repositories.
By connecting Microsoft Academic to your preferred search solution via BA Insight, you increase enterprise intranet adoption, improve organizational efficiency, and make research workflows simpler and more productive.
FAQ
FAQ
  • SharePoint Online/On-Premises, Azure AI Search, Elasticsearch, Amazon Kendra, Solr, Microsoft Search.
  • Yes, it federates search across both Microsoft Academic and internal enterprise data.
  • Yes, advanced filtering narrows results across federated sources.
  • Maintained to support new versions of Microsoft Academic and search platforms.
  • Yes, users see all results in one interface and can navigate directly to records.
Connect with us
