eBook
Will Telecom Expense Management Give You a Significant ROI?
Discover how to explain the value of TEM in plain ROI terms.
Like a lot of CIOs and IT managers, you probably have a hard time convincing your non-IT executives that they can get a significant return on investment (ROI) from a telecom expense management (TEM) solution.
Good TEM solutions save you 5-30% in telecom expenses.
The Telecom Expense Management Industry Association (TEMIA, now under the name of ETMA) jointly prepared with its members a free ePaper to help you out. Read “TEM, WEM and MMS Programs: Developing a Sustainable ROI, Cost Justification and Business Case” to answer these questions:
  1. What are telecom expense management (TEM), wireless expense management (WEM), and mobile managed services (MMS)?
  2. How do I create a sustainable business case for the use of TEM, WEM, and/or MMS?
  3. How do I show ROI from the use of TEM, WEM, and/or MMS?
  4. What is the state of my current TEM, WEM, and/or MMS environment?
You’ll discover great ways to explain the value of TEM in plain ROI terms and you’ll gain insight on your current TEM environment. Download this free ePaper by filling in the form on the right.
*Please note that Etelesolv has changed its company name to Cimpl in 2016.
*TEMIA is now Enterprise Technology Management Association (ETMA)
All fields are required
Resource header
eBook
Measurable Results and Real ROI: How Promotions Drive Consistent Results
Ready to grow advertiser revenue and build stronger partnerships? This guide makes it simple.
Read more
Resource header
eBook
7 Deadly Sins of Proposal Writing
Discover the seven key factors that can spell the difference between success and failure in your proposal writing efforts.
Read more
Resource header
eBook
Objectif Lune Technical Training Catalog
Discover training courses designed to build your knowledge of the OL Connect platform and other Objectif Lune solutions.
Read more
