Data Sheet
Datasheet for Finance
Learn how Eclipse PPM is helping Financial Institutions reach PPM success
Eclipse PPM provides an easy to use, out-of-the-box solution that is well suited financial organizations. The solution has been successfully implemented in hundreds of organizations using the ‘keep it simple’ approach. View our datasheet to learn how you can solve the challenge of managing multiple projects, requests, and significant operational commitments, with limited resources and budgets.
Download the Datasheet to read more.
Resource header
Datenblatt
RightAnswers X: The Enterprise Knowledge Browser Extension
Unify your knowledge base across every web-based application and deliver answers directly into your team’s workflow—zero coding required.
Read more
Resource header
Datenblatt
BA Insight for Amazon Q Business
Boost Amazon Q Business with BA Insight. Extend your AI assistant by connecting and indexing all your external content sources, supercharging productivity and delivering more accurate, high-value results.
Read more
Resource header
Datenblatt
Every superhero needs a Sidekick
Empower your agents to take on the day with superhero confidence and intelligence, with Sidekick.
Read more
