Microsoft SQL Server Connector for Search
The BA Insight Microsoft SQL Server Connector for Search integrates your organization’s SQL-based databases—including SQL Server, MySQL, Oracle, IBM DB2, and more—with leading enterprise search solutions such as SharePoint, Azure AI Search, Elasticsearch, Amazon Kendra, Solr, and others.
Leveraging BA Insight’s robust connector framework, the SQL Server Connector ensures secure, reliable connectivity. It supports both full and incremental crawls, automatically synchronizing the search index with new and modified database records.
Problems SQL Server Connector for Search Solves
Purple Slanted Bullet Point
Difficulty accessing and searching vital SQL database content without direct database access.
Blue Slanted Bullet Point
Disconnected search experiences when SQL-stored data is siloed from other enterprise content.
Security concerns about exposing sensitive or regulated database records to wider audiences.
Maintaining up-to-date search indexes as database content evolves—without manual intervention.
Benefits SQL Server Connector for Search Delivers
Key Features of the SQL Server Connector for Search
Use the left and right arrow keys to move between tabs. Swipe or drag to scroll through more tabs. Press Enter or Space to activate a tab.
Comprehensive Content Indexing
Securely indexes tables, views, and metadata from any SQL-based database, supporting both full and incremental crawls for always-current results.
FAQ
FAQ
  • Yes, the connector honors source database security, ensuring users only see information they are permitted to access.
  • Both full and incremental crawls are supported—automatically synchronizing the search index whenever database content is added or modified.
  • SharePoint Online and On-Premise, Azure AI Search, Elasticsearch, Amazon Kendra, Amazon OpenSearch Service, Solr, and more.
  • Any relational database with industry standard connection methods—such as SQL Server, Oracle, MySQL, and IBM DB2—can be connected and indexed.
  • No, the connector requires standard read access and does not need software installed on the database itself.
Connect with us
