Azure SQL Database Connector for Search
The BA Insight Azure SQL Database Connector for Search integrates Microsoft Azure SQL Database with leading enterprise search platforms such as SharePoint, Azure AI Search, Elasticsearch, and more. It enables secure and efficient indexing and searching of data stored in Azure SQL Database.
All without requiring direct database logins. This provides users with fast, relevant, and up-to-date search results across multiple data sources. BA Insight’s Azure SQL Database Connector is built on industry-standard database access protocols. It is also compatible with other relational databases like Oracle, MySQL, and IBM DB2.
Problems Azure SQL Database Connector for Search Solves
Bullet Image 1
Inability to efficiently search and access Azure SQL Database content without direct database queries or credentials.
Bullet Image 2
Fragmented search experiences caused by isolated database data siloed from other enterprise repositories.
Bullet Image 1
Security risks related to exposing sensitive database content during search integration.
Bullet Image 2
Maintaining up-to-date search indexes reflecting recent database changes without manual effort.
Benefits Azure SQL Database Connector for Search Delivers
Key Features of the Azure SQL Database Connector for Search
Use the left and right arrow keys to move between tabs. Swipe or drag to scroll through more tabs. Press Enter or Space to activate a tab.
Broad Database Compatibility
Designed for Azure SQL Database, also compatible with Oracle, MySQL, IBM DB2, and other relational databases via standard protocols.
This connector empowers organizations to integrate their Azure SQL Database data seamlessly into enterprise search ecosystems, delivering secure, up-to-date, and comprehensive search capabilities across SharePoint, Azure, and Elasticsearch platforms. BA Insight manages ongoing updates to ensure compatibility with evolving search technologies, simplifying maintenance for IT teams.
FAQ
FAQ
  • Yes, it enforces security permissions from the source Azure SQL Database, ensuring users access only authorized data.
  • It supports both full and incremental crawls to efficiently capture and index database changes.
  • Primarily designed for Azure SQL Database, it also supports Oracle, MySQL, IBM DB2, and other relational systems using standard database access methods.
  • No additional software installation is needed; the connector utilizes secure, standardized database access protocols.
  • Yes, content can be delivered through BA Insight’s SmartHub, enabling integrated search results across platforms.
Connect with us
