InterFAX Epic Fax Integration
Ready for InterFAX cloud faxing for Epic?
Integrate cloud fax directly into your Epic experience. Seamlessly.
Get started now
interfax epic integration diagram
Here’s how InterFAX works with Epic
We’re making healthcare communications and information exchange faster than ever by allowing users to send or receive faxes and access patient information all from one place. Simply sign up for InterFAX and get in contact with your Epic representative to have the InterFAX integration enabled in your environment, then start faxing! Easy as 1-2-3.
Learn more, then book a custom demo hosted by an InterFAX expert by providing your contact information.
Get started now
Get started now
All fields required
epic integration
Send faxes and track status right from your Epic dashboard.
InterFAX works well with Epic 2017+. Quickly set up an account, transfer existing fax numbers, and begin faxing securely in minutes with no downtime.
  • Send faxes directly from Epic, without having to leave the Epic interface.
  • Automatically deliver inbound faxes to specific network folders and attach them to the right patient record.
  • Access detailed records of every fax transmitted or received via the InterFAX web portal.
  • Create reports on fax usage by patient, sender, recipient, or customized fields to ensure compliance.
Epic is a registered trademark of Epic Systems Corporation.
Rest easy with secure, compliant fax
Data security is critical. InterFAX employs TLS encryption, user authentication, “delete upon delivery,” and more to ensure compliance with HIPAA, PHIPA, and PCI DSS.
Epic center
Work right from your Epic dashboard
Send faxes, verify delivery, access detailed records, utilize Epic data fields for enhanced reporting, and more all from your Epic dashboard.
Epic right
Communicate securely and reliably
InterFAX cloud fax accelerates the exchange of patient records, medical requests, and data exchange with other providers.
Epic left
Ensure every single fax is received
InterFAX verifies the fax was delivered to the right recipient, every time. Even in cases of failure, InterFAX will retry up to 6 times to transmit the message.
Epic center
Improve reporting using metadata
Send Epic data fields as metadata to streamline search and filter capabilities and enhance reporting capabilities.
Epic right
Ditch fax servers and go to the cloud
Reduce the burden of on-premise hardware and software maintenance for your IT team and let us handle the details.
Secure, reliable cloud fax is just minutes away.
We’ll handle the details around communications and PHI security. You focus on what really matters — providing your patients with fast, superior care.
Learn more
epic datasheet
Ready to get things done?
