Exploring the Benefits of InterFAX's Integration-Ready Cloud Fax
Team Interfax
What if you could send and receive faxes, track status, and add information to the correct patient files right from your web browser with cloud faxing? It’s already possible, and Upland InterFAX offers a cloud fax integration that works seamlessly with many of the systems you already have in place, so you can get down to the more critical business of streamlining secure communications.
InterFAX’s secure online fax solution has been configured to work seamlessly with the systems you use daily. That means your team can access everything they need efficiently, so they have time for higher-value tasks.
InterFAX’s cloud fax service allows healthcare providers to send or receive faxes and access critical patient information faster than ever. Best of all, there’s no downtime or training required because it integrates seamlessly with many of the systems your team uses daily, so your team can safely access PHI directly from the EHR/EMR. It only takes a few minutes to set up your cloud fax account, transfer any existing fax numbers, and begin faxing. You can even choose from our customized pricing packages so there’s just the right fit for your organization’s needs.
Our HIPAA-compliant information exchange integrates with Epic*, Salesforce, Microsoft, and more to accelerate communications, streamline referrals, ensure data security, reduce costs, and more. You can also create customized connections between your systems with our flexible developer API.
When it comes to providing patients with superior care, time is valuable. That’s why investing in reliable technology is so important. When every second counts, InterFAX saves time by simplifying workflow processes and eliminating unnecessary bouncing between programs, systems, and apps. It increases employee productivity by allowing healthcare workers to focus more energy on patient care and less on the headaches associated with inconsistent software.
  • Send faxes, verify delivery, access detailed records, utilize enhanced reporting, and more.
  • Streamline time-sensitive patient communications while meeting HIPAA, GDPR, SOX, and PCI DSS compliance standards.
  • Empower your staff by allowing them to manage communications and access detailed transmission records from their InterFAX dashboard.
  • Create reports on fax usage by customer record, sender, recipient, or customized fields to ensure compliance.
  • Reduce risk with a highly scalable, reliable infrastructure that seamlessly supports a wide range of geographically dispersed locations.
With our ever-growing cloud fax integration and versatile Developer API, you can choose from our customized pricing packages and personalize your web-based fax solution to fit your organization’s unique needs.
Ready to get started? Talk with a friendly cloud fax integration expert today to learn more about the possibilities.
InterFAX promotional banner with call-to-action button labeled 'Book it' to schedule a demo for cloud fax integration.
Epic is a registered trademark of Epic Systems Corporation.
Reliable products.
Real results.
